The washer will not fill. I filled it with water and it agitates . I put it on spin and it drained the water but it didn't spin.
I replaced the water inlet valve didn't help at all. Help
When you initiate a cycle it make three loud clicking noises and then starts to agitate.
When you lift the lid the agitation stops and when you close the lid it resumes.
Groups: Expert
Check the water level pressure switch. Should be closed with tub empty and open when full. There may be gunk in the air dome and hose on the lower left side of the outer tub hindering operation of the pressure switch. If the pressure switch is operating properly, check continuity from power cord neutral (large blade) and the wht/red wires on the water valve solenoid plugs and continuity from water valve plugs to control board. If pressure switch and continuity checks are good, it's likely a bad control board.
Eric
I disconnected the pressure switch and put the ohm meter on it and it read 0. does this mean it is faulty?????
Groups: Expert
It means that it is closed which is good for fill. It should open when the water level reaches the low level mark.
Eric
