HowieE
#1 Posted : Monday, April 1, 2013 10:57:00 AM(UTC)
HowieE
I have no voltage to the ice maker at the ice maker plug behind the ice maker. Where is that voltage coming from? Or where can I get a diagram?
#2 Posted : Tuesday, April 2, 2013 2:08:26 AM(UTC)
I could bnot find any info on the given model number.
Are you sure that there is not a X between the D and the W.
The following info relates to the GB9FHDXWB02
Here are the parts
Parts for Whirlpool GB9FHDXWB02 Refrigerator - AppliancePartsPros.com
See the attachments for the tech sheet
Looks like you have to hold the freezer light switch in for power to the ice maker.
File Attachment(s):
GB9FH.pdf (258kb) downloaded 16 time(s).
HowieE
#3 Posted : Tuesday, April 2, 2013 6:44:48 AM(UTC)
HowieE
WOW. Who would have thought the ice maker was coupled through the door switch
A second question
The ice maker was making HOLLOW ice cubes when i took it out. The cubes were hollow but there was no liquid inside them an no extra water in the collection tray. Not sure I can figure out how this happened and how to correct it.
Thanks again for the heads up on the door switch
HowieE
#4 Posted : Tuesday, April 2, 2013 9:43:36 AM(UTC)
Hollow cubes could be low water flow.
Just search the forum using advanced and tick the Refrigerator section.
Search for "hollow ice cubes"
