Sunny929
#1 Posted : Friday, March 29, 2013 1:54:49 PM(UTC)
Sunny929
At first it was stuck in drain mode unplug for 30 sec plug back in door locks pump keeps running, some how I got it in test mode and can't get it out keeps on going threw the Diagnostic cycle
sidfink43
#2 Posted : Saturday, March 30, 2013 3:51:37 PM(UTC)
sidfink43
I am not sure which model this is, but generally with your symptoms the main control unit is the problem.
Try changing it out. If you buy from this site and the control unit does not fix things you can return it.
