checked ignitor, looks ok, does any body know what voltage @ ignitor should be, 110 volt ac ? I don't have hooked to gas @ this time. took off lower cover, located ignitor, removed from mount, found no crackes, flat model, disconected 2 wires from ignitor, pluged in dryer, checked voltage @ wires, zero
