I got excellent help on here a few months back and replaced the clutch clip which had fallen off. It fell off again. I've removed the clutch and made a video of it hoping for advice on whether the clutch might be bad. I don't know if you can tell by looking at it. Here is the video. Any help will be appreciated. washer clutch march 2013 002 - YouTubeThank you!
Groups: Expert
Your not supposed to reuse the clip. Install a new clip. Eric
sorry I wasn't more specific. I did replace the clip about 2 months ago. What would cause it to fall off so soon? I thought the clutch might cause the problem. A video of the clutch is linked above.
Groups: Expert
I don't see how it can just fall off. Is it breaking?
Eric
it isn't broken. one of the arms looks like it might be bent outwards a bit, but definitely not broken like the one i replaced. here's a picture of it. http://youtu.be/RXyiLQivKQ0[IMG]http://youtu.be/RXyiLQivKQ0[/IMG]
I am having a similar problem. Did you end up replacing the clutch? Did that fix your problem?
