Gene, Thanks for your help on the Soap Dispenser replacement. You were right--I need to replace the Main Control Board-- would appreciate if you could clue me in on Removing the Old Control Board, Disconnecting all the clips(and Ribbon Connection) from the Old One and Reconnecting all the new clips(and Ribbon Connection) to the new one and re-installing the new one. Thanks for all your help! Really appreciate it. Jack.
Hi Jack, Unfortunately I do not have service manual for this model. Remove the inner door panel and then use your common sense. Good luck. - The control board Part number: W10285179
