The refrigerator and freezer both got warm and it appeared to still be running. I left to go out of town so I unplugged it. When I returned today I started taking it apart to find the problem and I started with the evaporator fan. After some dis-assembly I plugged it back in and the unit is running as is the evaporator fan. Both sides appear to be getting cold now. I know this will happen again so what are my most likely suspects. Thanks!!!
As an update it is still running and is ice cold the evaporator is starting to look like a blizzard came through. Is this the defrost heater?
