I went and replaced the start switch when it would not start because it felt like it was broken but the dryer still won't start. The owners manual says the thermal limiter may be tripped but I can't find any diagrams showing where the thermal limiter is, can you help.
The part is located on the pan in the rear marked in this photo as a non-resetable. Inside the dryer:
Unplug the dryer and remove it to the yard if possible. Start here:
