Don Walker
#1 Posted : 12 years ago
Don Walker
original problem was no spin with wet clothes. agitates well and pumps well both directions. installed new belts and brake assembly. failed to tell appliancepartspros about not being able to turn drive pulley and spin tub by hand. email back said to check tub bearing. seized! replaced tub bearing and seal kit. successfully ran spin cycle dry with no clothes or water. Now comes a new problem. will not agitate or spin with 1/2 load of clothes and water. pumps out water. Did i wreck new drive belt by testing and pumping out water several times before noticing the tub bearing was seized. do not remember if i touched brake assembly after the dry spin cycle test.
#2 Posted : 12 years ago
Hi Don,
You have to adjust belts tension after you replaced them by adjusting the pump belt. Did you do it? If not then follow the instructions attached to the post.
File Attachment(s):
Pump belt adjustment.doc (51kb) downloaded 6 time(s).
