AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore Elite Oasis Washer.Error# OL but won't Agitate
:confused: Can anyone help me. I have a Kenmore Elite Oasis Washer, blue top loader with the glass, Model # 11028087700 It starts up fine then during the wash cycle it just adds water, spins and drains but never agitates and at around 18 minutes it jumps to 3-4 minutes then drains and spins again but the clothes are always dripping wet and an error code comes on #OL I get this error code #OL (over load) with or without clothes, either way I still have the same problem even if I just use the clean washer button only. I read all the info hear and throughout the internet. I did the test that was posted here by ( tracehae, dated 01-02-2010, 10:57 AM) by grabbing the inside top lip of the basket on both sides and pull up and if the basket raises about 1 inch then it is ok. But if it does not raise then you know there is a problem, I don’t have this problem as my basket rises up fine. I read that I might need to have the circuit/control board replaced but thought I would see hear first if anyone has a thought of what I should do.Thanks for any help anyone can give me. :confused:
There are tech notes under the top. See if you can generate more diagnostics using them.
If you cannot then changing out the main control board is a good option. It is expensive but if you buy from this site and the part does not fix the problem you can return it.
good luck.
Washer Repair
