tr8d31
#1 Posted : Tuesday, March 19, 2013 8:41:30 AM(UTC)
tr8d31
Groups ready for retrieval: Registered
On my Whirlpool model GD25BFCHB00 side by side refrigerator both the water dispenser and ice dispenser stopped working simultaneously. The ice maker itself is working and produces ice. The freezer door switch is working. The dispenser lock is unlocked. The wiring at the bottom of the door looks fine. Given all this, I suspect that the switch (part# AP3086666) that is attached to the dispenser face plate is the problem. It seems unlikely that both micro switches have failed. Is this an accurate conclusion? Is there a way to verify?
I have removed the dispenser face plate from the freezer door but have not been able to remove the switch from the dispenser face plate. My unit has decorative wood panels so the dispenser face plate is larger than the standard face plate. It does not have a standard overlay that is removable from the face plate. The switch does move around within the plastic bracket enclosure but I see no way to remove it. I fear that the bracket holding the switch has been glued to the face plate and that I'm out of luck. I can upload pics if that would help. Any ideas? Thanks.
Simon / APP Team
#2 Posted : Tuesday, March 19, 2013 12:18:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It sounds like the bracket is broken and no longer holding the micro switches in the right position.
Part number: AP2988571
You have to figure out how to take it out.Normally there are 2 screws holding it down.
Sending the pictures may help.
Here are the breakdown diagrams and Dispenser Front parts for Whirlpool GD25BFCHB00 - AppliancePartsPros.com
Simon.
tr8d31
#3 Posted : Tuesday, March 19, 2013 12:42:34 PM(UTC)
tr8d31
Simon,
The bracket looks fine and both micro switches are in place. Any reason why you wouldn't suspect the switch attached to the faceplate?
Whirlpool 2180236 Switch - AppliancePartsPros.com
UserPostedImage
tr8d31 attached the following image(s):
Simon / APP Team
#4 Posted : Tuesday, March 19, 2013 3:00:07 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You can run the continuity test to check the switch.
For the lock continuity between BU/BK and GY.
For the ice GY - BU.
For the water GY - PU.
Post the results.
Simon.
tr8d31
#5 Posted : Wednesday, March 20, 2013 9:25:21 AM(UTC)
tr8d31
I don't see a PU terminal on the switch. Also there are 2 BU/BK terminals - which one?
Top row (left to right) TL/BK BU/BK WH/RD
Bottom row (left to right) BU/BK GY BU
See attached image.
tr8d31
#6 Posted : Wednesday, March 20, 2013 9:46:11 AM(UTC)
tr8d31
Here is the attachment showing the terminals on the back side of the switch. UserPostedImage
Simon / APP Team
#7 Posted : Wednesday, March 20, 2013 10:03:54 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The fastest way to determine the problem would be checking the door interlock switch.
You should have continuity between BK and BU/BK with door closed.
Next, check if there is 120VAC at the door switch BU/BK and check continuity of this wire to the push botton switch.
If you have continuity and correct voltage going to the selector switch - replace it.
Simon.
tr8d31
#8 Posted : Thursday, March 21, 2013 10:02:57 AM(UTC)
tr8d31
The problem turned out to be broken wires in the wire bundle underneath the freezer door. I did not examine them as closely as I had initially thought. Once you see how this wire bundle flexes every time the freezer door is opened you can see that the wires are guaranteed to eventually break. A very poor design in my opinion. Thanks for the help.
Simon / APP Team
#9 Posted : Thursday, March 21, 2013 11:32:47 AM(UTC)
Simon / APP Team
Groups: APP Team
I'm glad you found the problem.
Good job.
Simon.
