Babieca
#1 Posted : Saturday, March 16, 2013 3:14:42 PM(UTC)
Babieca
Hi all,
I have a GE Profile Prodigy electric dryer that won't start.
The screws holding the drum to the bearing had stripped out so I just replaced them. I turned the dryer on and it ran great. opened the door to check that the drum was spinning and then it wouldn't turn on again.
I checked the timer switch, the door switch, thermal fuse, and start switch and they are all good.
Behind the switch panel there is a green ground wire that is connected to the panel with a screw the other end has a terminal clip but is not connected to anything. Is that what is causing the problem? I cannot see where it is supposed to clip to.
Any help would be greatly appreciated.
dryer dummy
#2 Posted : Saturday, April 6, 2013 12:04:52 PM(UTC)
dryer dummy
Do you have the wiring diagram that goes to the machine? I've had the spade connectors come loose after having the machine apart.
