IXLR8
#1 Posted : Wednesday, March 13, 2013 12:22:17 PM(UTC)
IXLR8
Hi--
I have replaced both the mother board and the temp indicator/control board. My temps are 0 for the freezer and 37 for the fridge.
My water flow was intermittent and now has not functioned for about 10 days.
What should i check next?
Thanks in advance for your help.
Joe
Simon / APP Team
#2 Posted : Wednesday, March 13, 2013 12:55:41 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull off the bottom grill and locate the connector on the water line going into the freezer door. Disconnect it on one side and with the door closed push the water lever at the dispenser.
If the water comes from the tube - you have a frozen water line inside the freezer door.
You will need to defrost the fridge and install the dispenser tube heater
Part number: AP4318572
Here are the breakdown diagrams and Freezer Door parts for GE PSI23NGNABB - AppliancePartsPros.com
Post the results.
Simon.
IXLR8
#3 Posted : Wednesday, March 13, 2013 1:39:24 PM(UTC)
IXLR8
Hi Simon--
Well, I had my wife push the dispenser lever while I checked whether voltage was coming to the water valve, and the water started flowing. FIXED!
Thanks,
Joe
Simon / APP Team
#4 Posted : Wednesday, March 13, 2013 1:47:54 PM(UTC)
Simon / APP Team
Groups: APP Team
That is a success story. Congratulations.
Simon.
P.S. It's got to be your wife's touch. :)
