Kind Sir/Madam: [FONT="Times New Roman","serif"]If I have power to my Bosch Model[/FONT][FONT="Times New Roman","serif"]SHU8805UC/UC12[/FONT][FONT="Times New Roman","serif"]dishwasher’s junction box, with secure black-to-black (power), secure white-to-white(neutral) and proper grounding, but the dishwasher is utterly functionless (nolights or operation) in response to depression of the power button or either of the threecycle buttons, should I not first check the on-off switch (AP2802323) forcontinuity? Can you direct me toa wiring diagram? Second, with no response to the on/off switch, the 3-program control module (APO2804377 is not a likely culprit,is it? And, third, is there anythingelse that I should be checking, before ordering the on/off switch (AP2802323) and/or the Control module, 3-program, Shu 88 (AP2804377)? DIY Lawyer.[/FONT]
It was the control module, 3-program, Shu 88 (AP2804377)--received and installed this afternoon. Thanks. DIY Lawyer
