Originally Posted by: jsarp59 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Noticed the mount where the top switch pushes into only has one plastic prong that fits into the hole in the switch. Is this normal or did one break off? All the other mounts have two prongs that fit into the two holes in the switch... Does the switch stay firm? If it's moving then the bracket has to be replaced. This part is no longer available. If the switch stays firm then it's better to replace the switch. Gene.
Ordered a new top switch from you guys (best price hands down). Ordered on a Saturday. In my hands Tuesday (you aren't kidding it is fast delivery). Took the old switch apart. It was smoked inside and the contacts arced. Pretty sure this was the problem. Thanks so much for the help.
You are welcome. I'm glad you were able to fix it and it was pretty easy.
Thank you for the feedback.
