smammi9
#1 Posted : Tuesday, March 12, 2013 3:21:27 AM(UTC)
smammi9
I have a maytag mtb1956bew freezer/fridge that does not feeze and the fridge half isn't cold enough. I removed the back panel in the freezer to see if the evaporator was iced up but it wasn't. Only minor icing. I then pulled out the fridge to clean the dust from the compressor and condenser coils. Compressor runs but freezer is still not working.
#2 Posted : Tuesday, March 12, 2013 1:59:49 PM(UTC)
Seems like a bad compressor/refrigerant leak.
smammi9
#3 Posted : Tuesday, March 12, 2013 2:43:07 PM(UTC)
smammi9
I was thinking it was that or maybe a bad defrost timer. Could the timer be stuck?
smammi9
#4 Posted : Tuesday, March 12, 2013 3:11:17 PM(UTC)
smammi9
I took out the defrost timer and found a burn mark on the #1 pin terminal. Any way to test it?
#5 Posted : Wednesday, March 13, 2013 12:59:10 AM(UTC)
If the compressor is running constantly and you have very minimum frosting of the evaporator, you have a bad compressor/ refrigerant leak.
smammi9
#6 Posted : Wednesday, March 13, 2013 1:49:23 AM(UTC)
smammi9
Sorry but I originally gave the wrong info. I had mistaken the evaporator fan noise for a working compressor. The compressor is not turning on.
#7 Posted : Wednesday, March 13, 2013 12:51:29 PM(UTC)
If the compressor and condensing fan motor are not working, you probably have to replace the defrost timer, probably your problem based on the burn mark.
smammi9
#8 Posted : Friday, March 15, 2013 9:02:07 AM(UTC)
smammi9
just tested and installed the new defrost timer. i have a resistance reading between the #1 &#3 pin terminals now however the evap fan in the freezer is still blowing warm air for about an hour now. compressor and condenser fan are now operating. compressor is getting very hot to touch. normal?
#9 Posted : Saturday, March 16, 2013 1:04:15 AM(UTC)
If the condensing fan is running, the condenser coils clean,and compressor is vibrating, you probably have a refrigerant leak that probably damaged the compressor.
