Nocturnal1
#1 Posted : Monday, March 11, 2013 12:09:14 AM(UTC)
Nocturnal1
Hi, I have a Norge (Magic Chef) DU6550P dishwasher that "drains" during the wash cycle. Everything else works fine. I suspect that the drain flapper and/or drain flapper seal is leaking and would like to inspect/replace it.
I've removed the motor and pump housing assembly from the chassis. I think I need to remove the impeller and then the pump volute to gain access to the drain flapper. However, I can't remove the impeller.
I "jammed" the motor shaft and tried turning the impeller clockwise and counter-clockwise, but the impeller won't move. I'm beginning to round the hex on the end of the impeller. Is there a trick to removing the impeller? Do I need a special tool? Does anyone have a service manual for this? Do I need to remove the pump volute and impeller to gain access to the drain flapper?
Thanks in advance for your help.
#2 Posted : Monday, March 11, 2013 2:50:12 PM(UTC)
You may want to check the drain solenoid too. The manual is attached to the post.
Here are the breakdown diagrams and Parts for Magic Chef DU6550P Dishwasher - AppliancePartsPros.com
File Attachment(s):
16008775 - Magic Chef - Pump Assembly.pdf (568kb) downloaded 2 time(s).
