I do not see error code F2-E9 on list.Does my model have a clock or is it only a digital board.Please help:confused:
As you can see it says on the page 4 of the Tech sheet that any meaning of a fault code "F2" is related to a problem with the keypad assembly. If you need the correct part number then post the color of the control panel. There is also the electronic oven control which you can call a digital board. Gene.
