roger1477
#1 Posted : Friday, February 1, 2008 4:51:51 PM(UTC)
roger1477
after wash cycle water does not drain. tried reset and sometimes it will drain and other times it won't
#2 Posted : Saturday, February 2, 2008 1:37:18 AM(UTC)
I would first check the piston and nut check valve under the filter at the back of the unit, It might me stuck open, if so, order a new one p#AP2617344
If ok, pull out unit and check the pump and clean any items stuck in there.
Dishwasher drain problem (Dishwasher Repair)
by hunterman 11/14/2011 7:56:54 AM(UTC)
Maytag Dishwasher drain problems since accidentally using dish soap once (Dishwasher Repair)
by sjuid 11/21/2010 12:54:10 AM(UTC)
dishwasher drain problem (Dishwasher Repair)
by majorwalker 9/7/2009 4:33:27 PM(UTC)
