Richie70
#1 Posted : Thursday, March 7, 2013 3:42:38 PM(UTC)
Richie70
Our YWED9200SQ0 dryer was running and my wife opened the door to check if the clothes were dry, they weren't quite dry so she went to restart but the dryer would not run. I checked the error code and it read F25. Thermistor was good so next recommended action was to replace control board. I purchased a refurbished unit and installed it, but the dryer still wouldn't start. A new error code F70 comes up. Wiring between console electronics was good and when I put the old control board back in the F25 error coded came back. Any recommendations and what to do next?
#2 Posted : Friday, March 8, 2013 1:13:21 AM(UTC)
Parts for Whirlpool YWED9200SQ0 Dryer - AppliancePartsPros.com
Unplug the unit.
Unplug the inlet thermistor at the control board.
Plug unit in.
Check for the error code
If it changes from F25 (shorted) to F24 (open), then odds are that the thermistor needs replacing.
To confirm this check it with a meter, see table C on Page 10.
If the error code stays at F25 then the board is toast.
Your refurbished board is probably no good.
You could try the following but I doubt it will help as the od board does not show any communication errors.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
YWED9200.pdf (1,125kb) downloaded 1 time(s).
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Mah2400aww Maytag Door Boot Door Diaphragm Discontinued, Help! (Washer Repair)
by DIY_Vee 3/4/2022 7:34:13 AM(UTC)
Ice maker dispenser will not stop running - help! (Refrigerator & Freezer Repair)
by Guest 1/30/2022 7:11:17 PM(UTC)
Maytag Bravos MCT HELP!!!!! (Washer Repair)
by Guest 10/23/2021 7:31:14 AM(UTC)
Help! Does motor need to be replaced or cleaned out? (Dishwasher Repair)
by connellh 4/30/2021 8:36:32 AM(UTC)
Kenmore not cooling - Can't get a replacement fridge HELP! :) (Refrigerator & Freezer Repair)
by shorton 11/9/2020 11:33:04 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
