Water has started leaking inside refrigerator from the controls located in the center of refrigerator compartment, or that is where it looks like it is coming from. I use it as a spare and dont have the ice maker hooked up. I have tried setting the energy saving button both ways, but It still leaks a small puddle onto the crisper every day.
Originally Posted by: mark goodnight  Water has started leaking inside refrigerator from the controls located in the center of refrigerator compartment, or that is where it looks like it is coming from. I use it as a spare and dont have the ice maker hooked up. I have tried setting the energy saving button both ways, but It still leaks a small puddle onto the crisper every day. Sounds as though your defrost water drain is clogged. Usually there is a cup in the back of your fresh food section that catches the water and carries it down into the pan underneath the refrig. Without the model it will be hard to get much more specific.
