AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore Washer not spinning at the end of cycle
Washer agitates just fine, drains, lid switch is good. I am running it on a fast wash and fast spin but the clothes are soaking wet at the end of the spin cycle.
Groups: APP Team
Hi. First you need to remove the agitator and check the drive block condition. See if the grooves are intact and it's engaging the spin tube Part number: 389140
If the drive block is good - replace the clutch assembly Part number: 3951311
Use the video clip for the instructions. Post the results. Simon.
Washer Repair
