Frigidaire Model FDB345LBS0 Dishwasher - At the end of the wash cycle it gets stuck and keeps washing until you move the knob a little then it continues on just fine. Been doing this for awhile and the wife says fix it or get a new one. I'd rather fix it. Any suggestions?
Thanks, Doug
Hi Doug, If it does wash good and this is the only problem then most likely the timer is the culprit. - The timer Part number: 154408901
