ken freeman
#1 Posted : Friday, February 1, 2008 11:25:23 AM(UTC)
ken freeman
I need help getting the front panel back on. This is a tough job. How do I do it? Any hints?
semojim
#2 Posted : Sunday, January 17, 2010 5:47:27 AM(UTC)
semojim
Did you ever find out how? I can't figure out how to get the fron panel off.
ghhardy@cogeco.ca
#3 Posted : Friday, January 27, 2017 9:03:44 AM(UTC)
ghhardy@cogeco.ca
On my Bosch, after removing the small screws along the left and right side (3 on each side), return the door to the closed position and tug the panel out from the bottom. Then slide it downward until it clears the upper control panel (less than 1 inch), and it's free.
Reinstall with door closed, slide upper edge up behind control panel, then push the bottom back into position. Support the lower edge with your hand, carefully open the door and put in a screw loosely on each bottom hole to hold the panel in place while you install the rest of the screws
bosch dishwasher front panel reassembly help needed! (Dishwasher Repair)
by lindam02 8/21/2010 2:17:42 PM(UTC)
