alfalover
#1 Posted : Friday, March 1, 2013 4:13:06 PM(UTC)
alfalover
One of the Two Broiler Elements Not working.
Is it easy fix.
What is my next step.
KitchenAid
KEWM378s
#2 Posted : Saturday, March 2, 2013 4:57:53 AM(UTC)
Parts for KEMS378S - AppliancePartsPros.com
Your model number is missing several characters at the end of it, so choose the correct one from the Matching Model Numbers section.
Unplug or remove power from the unit.
Remove the broil element from the unit and check the heater with a meter, should be around 30 ohms.
It is a good idea to clip something (clothespin etc.) to the wires so that they do not disappear into the back of the unit.
If it is OK then odds are that the control board is toast.
If you click on the broiler element picture in the above parts link a new page will open with more info/help on it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
