rld2021
#1 Posted : Thursday, February 28, 2013 12:18:23 PM(UTC)
rld2021
Please help. I have a Kitchedaide side-by-side refrig and the vegetables keep freezing. I replaced the refrig thermostat and still no luck. When I shut the little slide door on the inside of the refrig frost develops on it as it the air never stops blowing out of it. Could this be a damper issue? Does this little slider door attach to the damper which is in the upper back? What controls the air coming out of the little slide door?
#2 Posted : Friday, March 1, 2013 3:25:02 AM(UTC)
A model number may help others help you
Find your model number - AppliancePartsPros.com
