scifime
#1 Posted : Wednesday, February 27, 2013 4:07:59 PM(UTC)
scifime
Not enough flame pressure for this GE JGBP29SEK3SS stove coming out of burner, just replaced all 4 of the burners. They were not lighting, had to use something and hold against the ignighter to work. They are working a little better except one now, but not all the way. Is there a way to adjust the pressure of the gas going through to the burner to make it burn hotter, and it so are there any instructions for that somewhere. Takes forever to cook anything. Thanks for any information that someone might have to help.
#2 Posted : Thursday, February 28, 2013 12:53:17 PM(UTC)
Remove the burner caps and burner heads. Using a toothpick, clean the central hole in all orifices.
Here are the breakdown diagrams and Parts for GE JGBP29SEK3SS Range - AppliancePartsPros.com
Guest (5)
