Is there a way to purchase just the rubber double valve in the middle of the feed tube assembly listed below? It comes apart easily to allow a new rubber valve to be installed. That's the only thing wrong. One of the valve flaps won't stay closed to direct all the water through the rack manifold.
Part Number: AP3177989 MFG Part Number: 8539167 Made by: Whirlpool
Sorry but it looks like the valve is not available as a separate part. |
THIS FORUM IS DEAD!!!!!!! |
