I have a Kenmore 90 Series washer dryer set and the washer has gone caput.. A year ago i changed the coupling on the motor and now after a year of no problems the washer will not drain. since it will not drain it won't spin. i have drained it manually and have replaced the timer mechanism as all signs pointed to it as the culprit. however it still will agitate, and then stops before the drain cycle. the pump is free of debris and rotates, the motor is fine when agitating and it appears that no power is going to the motor as thier is no cycle hum when it is supposed to be draining. any help would be appreciated.
Check your lid switch. Need model # to help further.
