gyorgypapp@hotmail.com
#1 Posted : Friday, February 22, 2013 8:20:40 PM(UTC)
My whirlpool duet tumblefresh washer.now it keeps stopping at the wash cycle- It fills up okay,than drains and then it gets stuck at the wash cycle....it keeps beeping ( like beep beep beep , beep beep beep, 3 quick beeps)and the wash light is blinking I changed the drain pump and the problem is still there.there is no error code because no digital display.It just past the one year mark :mad:
please help
03/06/2013
I opened the top by unscrewing it from the back and I saw a wire broken ,than I patched it up ,it works now :)
sidfink43
#2 Posted : Tuesday, February 26, 2013 1:33:52 PM(UTC)
sidfink43
Take off the top of the machine, the screws that hold it on are in the back, and you should find some tech notes that will show you how to put it into a test mode. Focus on the door lock assembly and the motor control board.
If it will not go into test mode, then the problem is likely the main control board.
