The water dispenser does nothing. The ice maker works good. New water filter. When I press the dispenser pad the dispenser light does not come on like the ice maker pad does. It seems like a switch on the dispenser is not working. All the dispenser parts list I have seen don't show a switch! Please help. Thanks
The switch is in the pad that you press when you want water. Anyone know how to take the front control out? Thank You
Ok, I checked the pad with an ohm meter. Its bad. The pad seems easy enough to remove but it won't budge. thanks for any help you can give.
