2 Pages12>
kylasm
#1 Posted : Wednesday, February 20, 2013 8:41:08 PM(UTC)
kylasm
From what I've read here (and many other sites) I need a new motor in my Maytag Gas Dryer MDG9206AWW. Buzzes/hums but doesn't tumble...burnt smell if I hold the start button. There seems to be many motors available for this model. How do I know which motor to buy? I'm nervous about taking the entire dryer apart/putting it back and causing more damage trying to get any identification from the old motor. First time replacing a motor!:eek:
Simon / APP Team
#2 Posted : Thursday, February 21, 2013 10:05:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi
The motor you are looking for is
Part number: 33002478
But before replacing it check if the blower wheel is not jammed, causing all the problems.
Here are the breakdown diagrams and 06-Motor Drive parts for Maytag MDG9206AWW - AppliancePartsPros.com
Post the results.
Simon.
kylasm
#3 Posted : Thursday, February 21, 2013 3:29:47 PM(UTC)
kylasm
I'm not sure how to get to the blower wheel, my set up is a little different than the diagram. I do see a rubber gasket hanging from what seems to be the housing blower but I can't tell how it should be sitting.
Simon / APP Team
#4 Posted : Thursday, February 21, 2013 3:55:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Did you open the front panel and remove the bulkhead to get to the blower housing?
What do you mean by your set up is a little different? It's the same model number isn't it?
Simon.
kylasm
#5 Posted : Thursday, February 21, 2013 4:11:17 PM(UTC)
kylasm
It is the same model thought maybe a difference between serial no.? The large plastic part connecting the lint trap to the blower wheel isn't named in the diagrams and couldn't find any screws or a way to remove it. That's where the gasket was hanging from, the plastic part and where it meets the blower. I got my fingers in the blower wheel after I moved the seal and it did seem stuck for a second then moved and turned the drum.
Simon / APP Team
#6 Posted : Thursday, February 21, 2013 4:26:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Did you open the front panel and remove the bulkhead?
Simon.
kylasm
#7 Posted : Thursday, February 21, 2013 4:56:31 PM(UTC)
kylasm
Yes I did get it open and blew out some of the lint and hair while it was open
Simon / APP Team
#8 Posted : Friday, February 22, 2013 9:48:19 AM(UTC)
Simon / APP Team
Groups: APP Team
Take the belt off the motor pulley and turn the blower.
If the motor turns easily - replace it.
Simon.
kylasm
#9 Posted : Sunday, February 24, 2013 8:29:32 PM(UTC)
kylasm
Alright, since it's not the motor what do I do to make sure the blower wheel doesn't jam?
Simon / APP Team
#10 Posted : Thursday, February 28, 2013 12:20:57 PM(UTC)
Simon / APP Team
Groups: APP Team
What made you decide that it's not the motor?
Simon.
2 Pages12>
