shula
#1 Posted : Wednesday, February 20, 2013 5:27:35 AM(UTC)
shula
After reading the other posts, I went ahead and purchased the water valve. One of the green ground wires pulled off in the process and cannot find where to re-attach it. See picture. So far, replacement of the water valve did not fix the problem, unless attaching this green My Slideshow - YouTube wire is the problem? Bosch Dish Washer Problem 0001 - YouTube
jkonken
#2 Posted : Sunday, February 24, 2013 11:47:12 AM(UTC)
jkonken
Did you find out where the green wire goes? I have the exact same problem
jkonken
#3 Posted : Sunday, February 24, 2013 2:11:26 PM(UTC)
jkonken
shula
#4 Posted : Sunday, February 24, 2013 3:17:14 PM(UTC)
shula
Yes, behind the water valve, left hand side of the frame. There is a silver nube sticking straight out points toward where the other two wires hook on right of the water valve. About 50 seconds into the video. https://www.youtube.com/watch?v=TZ-Bt7-x3V8
P.S. I went to the Bosch website, this is part of a recall, Bosh is sending a repair man out the replace the module (fire danger)
