Ted Rzewucki
#1 Posted : Friday, February 1, 2008 9:15:59 AM(UTC)
Ted Rzewucki
02-02-08
Hi!
My dryer does not work. Starts than shut off.
What is the problem?
Kinly reply
thank you.
Ted
#2 Posted : Friday, February 1, 2008 1:57:03 PM(UTC)
Hi Ted,
Looks like the model number of your dryer is Canadian.
If it is then we are not able to get any information.
It this is not a Canadian model number then I need you to verify and repost it.
kayakcrzy
#3 Posted : Friday, February 1, 2008 2:48:09 PM(UTC)
kayakcrzy
when your dryer shuts off, does it have to sit a little bit before it will come on again. If so you need a motor. Tom ApplianceEducator.com
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
