jegfla1
#1 Posted : Tuesday, February 19, 2013 1:31:56 PM(UTC)
jegfla1
Our whirlpool washer will only work in the extra rinse cycle. I have replaced both the timer and the auto load sensing switch.
The washer fills correctly, agitates, and rinses all in the extra rinse cycle but will not in any other cycle.
Any ideas?
Simon / APP Team
#2 Posted : Tuesday, February 19, 2013 2:23:15 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Did you replace the W10292584?
Simon.
jegfla1
#3 Posted : Tuesday, February 19, 2013 4:11:14 PM(UTC)
jegfla1
Yes, I replaced the load sensing switch (W10292584, replacement for W10177795) and the timer (W10177827).
Other forums I'd read across the web pointed to the load sensing switch first, then the timer second. I have replaced both and the machine's behavior has not changed; it still only operates in "Extra Rinse" cycle.
Some posts have suggested the lid switch, but when the machine is running in the "Extra Rinse" cycle and the lid is opening, the lid switch shuts down the machine as intended.
Any thoughts would be greatly appreciated.
#4 Posted : Wednesday, February 20, 2013 3:07:12 PM(UTC)
On which water temperature it was set?
Set it for cold water only and give it a try.
jegfla1
#5 Posted: : Thursday, February 21, 2013 5:53:44 AM(UTC)
jegfla1
I have tried starting the machine in the all of the various temperature options without success.
xterra
#6 Posted : Monday, April 29, 2013 12:15:14 PM(UTC)
xterra
I have similar problem with my whirlpool washer, it operates in extrarinse only, does not operate in other cycle modes, it just spins in other cycle modes.
