I have sharp carousel 520LW-T, I had to adjust the micro switch on the door had to take the sheet metal off the outside. How do I get the sheet metal back in place on the front of the cabinet?
Groups: APP Team
Hi.
There are tabs on the top and sides of the cover. You have to match this tabs with grooves of the frame. Put the top first and then bend a bit and lock the sides one at the time.
Good luck.
Simon.
Good luck.
Simon. Thank you for your reply. I figured it out yesterday afternoon.
Groups: APP Team
