steve7793
#1 Posted : Sunday, February 17, 2013 6:11:42 PM(UTC)
steve7793
Maytag washer does not spin in reg cycle but works in drain and spin,lock lid flashes and then unlocks while spin light is still on and clothes are soaked . Any ideas?:(
#2 Posted : Monday, February 18, 2013 7:15:33 PM(UTC)
Hello Steve,
The problem can be a bad lid latch or a bad control board.
Perform the test #8 as described on page 18 of the attached tech sheet to figure out which part is bad.
- The control board Part number: W10393490
- The lid latch Part number: W10404050
File Attachment(s):
Tech Sheet W10280489 - MVWC400XW0 - part 1.pdf (1,470kb) downloaded 52 time(s).
Tech Sheet W10280489 - MVWC400XW0 - part 2.pdf (1,696kb) downloaded 41 time(s).
