AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Gold Ultimate Care II(Pump Continually Clogging with socks)
Pump keeps getting clogged with socks. I have taken it apart 3 times unclogged the pump and ran the washer through a complete cycle with no clothes and it will work fine. But when I put clothes in a cycle it will clog. Is there a drain filter or something that I may be missing?
Can't really say to much without a model number, but if this is a top loader it is probably filling too high. Fixed the water level problem or run it on medium and that may solve your problem.
Washer Repair
