2 Pages<12
fairbank56
#11 Posted : Sunday, March 3, 2013 7:25:09 AM(UTC)
fairbank56
Groups: Expert
Can you upload a clear photo of the wiring diagram and timer chart? According to the sears parts website, your washer has a 3-speed motor which would have the extra connector with wht/vio and wht/orn wires. The water level switch only places the machine in agitation mode and provides power to the timer motor during agitate. At the end of agitate mode, a set of timer contacts (#2)(pressure switch bypass) close to provide power to the timer motor and main drive motor. This is in series with the lid switch, so it appears to be either a bad lid switch, timer, or faulty wire connector/connection.
Eric
capnrobi
#12 Posted : Tuesday, March 5, 2013 4:22:51 PM(UTC)
capnrobi
It is working.
Thank you Gene, Thank you Eric
It was either a lid switch problem right at the connector,
or fixed while moving things around for tests.
>Eric your washer has a 3-speed motor which would have ...
Yes, a separate connector 4.5 ohms.
RKF22
#13 Posted : Tuesday, March 5, 2013 4:39:43 PM(UTC)
RKF22
I'd check the lid switch. unplug it an then jump the two colored wires with a jumper wire. Not the green wire. That's the ground.
Kenmore not draining completely (Washer Repair)
by csohio 12/23/2008 10:08:17 AM(UTC)
Kenmore not draining or spinning (Washer Repair)
by Alicornat 6/28/2008 12:45:10 PM(UTC)
2 Pages<12
