jhalpern
#1 Posted : Thursday, February 14, 2013 9:46:56 PM(UTC)
jhalpern
Hey guys. Can't locate the part for what I would call the idle pulley. I am referring to the pulley that sits on the front right underside of the unit and apparently just keeps the belt on the transmission and motor pulleys in alignment.
Need to replace it as it's making noise and wobbles cockeyed!
I've checked 10+ places and no one lists the part, nor is it in any of the parts diagrams. Confirmed that model number 3 times already...
Thanks!
Jason
fairbank56
#2 Posted : Friday, February 15, 2013 5:04:53 AM(UTC)
fairbank56
Groups: Expert
That is the pulley on the drain pump, there is no idler pulley. You will have to replace the drain pump.
Eric
