lower element cool to touch when preheating. will eventually come to temp because broil element cycles.
bake element 22 ohms temp sensor 1010 ohms and climes when heated
where is the DLB remote relay located? would like to look at that before changing the control panel out.
Groups: APP Team
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks Simon, The electrical drawing shows "DLB remote relay" so i'm thinking remote would be off control panel perhaps close to the power block. so would access be from the back panel? I also found a DLB relay under p/n 71002453. this is driving me nuts!!!
Groups: APP Team
What is the serial number of the unit?
Simon.
Groups: APP Team
There is no external relay on your unit.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There is no external relay on your unit.
Simon. Was it 19 and below with no DLB / 19 and above with DLB or was it just Canadian models. ok so everything is in and controled by the panel.
Groups: APP Team
It's 20 and up with DLB.
Post the results.
Simon.
ok will change the control panel
Thanks for the help
Groups: APP Team
