Washer won't drain after wash cycle. Goes into rinse cycle and just sits. When it spins it spins slowly with a loud knocking noise. During the spin the water drains.
I have checked the lid switch - it is working. Checked the pump and all hoses - they are clear. I replaced the timer, but the problem didn't seem to be with that as the problem hasn't changed.I checked the motor coupling and it is fine.
Could it be the transmission?
