I set the oven temp to 425 and the oven heats up to 250. It may get to 300 over time but does not heat up much more even if it put it to 500. Is this a thermostat or contol problem?
Cannot find any info on this unit so the below is just generalized info. Is this a thermostat or contol problem?Could be either but it is easiest to check the thermal sensor first. Also on most units the bake and broil come on during preheat so if one of them is not working it will also take a long time to get to temp. Here is a good site with basic oven troubleshooting, sensor checks etc. http://www.applianceaid.com/elecrange.htmlSee Items 7 and 8 |
THIS FORUM IS DEAD!!!!!!! |
