makinice
#1 Posted : Monday, February 11, 2013 7:57:10 AM(UTC)
makinice
The freezer temp is -15 ref side 36. the evap eventually freezes up. when it attemps to defrost water runs inside of the freezer cabinet. have cleaned the drain tube. and eventually freezes up again. checked the ref side thermister, 2.96k ohms at 72 degrees. print show thermister in the freezer side but I cannot locate it. The high temp alarm sounds on control panel. freez temp -15 ref 35. changed main control board. same problem after two days.
Simon / APP Team
#2 Posted : Monday, February 11, 2013 2:53:57 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Use the attached link to initiate the self diagnostic mode.
Here are the breakdown diagrams and Cabinet parts for Whirlpool KSRA22FKSS00 - AppliancePartsPros.com
Simon.
File Attachment(s):
KA SxS electronic controls KSRA22 and 25 FK.pdf (862kb) downloaded 15 time(s).
evap iced up (Refrigerator & Freezer Repair)
by godivadog 6/14/2010 7:38:10 AM(UTC)
