johncher
#1 Posted : Saturday, February 9, 2013 2:43:39 PM(UTC)
johncher
The unit makes a very loud single bang when spinning stops. I have replaced the snubber ring. Can you tell me what the problem is?
sidfink43
#2 Posted : Tuesday, February 12, 2013 4:59:08 PM(UTC)
sidfink43
This sounds very much like a brake problem, and you may need to change out the parts. However you will need a special tool to safely compress the brake spring as it is under huge pressure. Be very careful.
