Hello very helpful people! I am trying to do several things... I'll list them to make our lives easier. #1. Find out WHY I keep getting moisture at the bottom of the door. I'm pretty sure it has something to do with the seal. I keep cleaning it off and around it, yet it STILL gets moisture on it. #2. Lint trap is warped... I think this might be a "duh" thing... just order a new one. I just want to be sure it's the lint trap and not the "grate" that holds it in. #3. Would the lint trap being warped + the moisture from the door not sealing properly be the reason why the lint chute has a lint "coating" that is a pain to remove? It's like the vacuum hose is not enough, I need to actually rub the surface to get that mess off of there! And, i want to get all the way thru, so is the back of the dryer the easiest way to clean the lint chute all the way out? Thanks guys for your help!!!
In reply to my own thread, patience IS a virtue! :o I found the reason why the lint trap was warped... In the past, I had removed the "grid" and didn't put the lint chute back correctly. Now that it's back on correctly, hopefully I can quell some of the moisture! Much Better!
