plastra
#1 Posted : Friday, February 8, 2013 11:56:50 AM(UTC)
plastra
Many times the Water dispenser will come on by itself and then shut off. It does this repeatedly. On more than one occasion I have found water all over kitchen floor, luckily it's tile. The easiest way I've found to stop it without shutting the water feed is to put the child lock on. At first I was able to take the child lock off and use the dispenser and then lock it again, but now the dispenser come on intermittently. I noticed on the internet that many people have had the same problem with this model refrigerator, unfortunately no repair recommendation were made. The ice maker works fine. Initially I replaced the water filter and bled the line to make sure that was not causing the issue.
#2 Posted : Friday, February 8, 2013 5:53:44 PM(UTC)
Hello,
Sounds like the problem is with the dispenser control. It comes as a part of the dispenser cover assembly. In order to remove it remove the screw under the display cover. Then remove the display cover by pushing it to the right side and pulling it up.
- The display cover assembly Part number: DA97-08518D
