How do you replace the door hinges on a Thermador oven M# prg304us
Hello Greg, Open the oven door to its fully open position. Raise the hinge latch over the hook on each of the hinges. Grasp the door by the sides toward the back, then raise the front of the door several inches (there will be some resistance in the spring mechanism because the hinge is locked). When the door is high enough, lift the door until the hinges clear the indents, and pull it out of the slots in the front frame. Place the door with the handle down on a protective surface and remove the screws securing the inner door liner. Use the diagram to remove the door components. - The door hinge Part number: 487536
