side by side top mounted compressor and condensor. opening on the right side when faceing the doors. using a long condensor brush is only cleaning about half even when using the vacuum with a clevice tool. also i can not get to the fan to clean the blades. is there a better way then taking the complete cover off? also can i use a loose furnace filter at the conrensor opening? thanks for taking the time to help.:confused:
