Here are your parts includes a wiring diagram.
Parts for Admiral LNC7764A71 Dryer - AppliancePartsPros.comI would find out what part is bad before ordering anything.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Could be that it is a power problem and not a machine problem so I would start there.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
L1 is the motor drive voltage
If OK
If OK
To check the thermal fuse
Unplug the unit and check the fuse with a meter should be 0 ohms.
This is the safest method.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
